TouchDJ from Amidio Released!
9 μηνύματα σε αυτό το θέμα
#1   jwr
jwr
  • 1.090 μηνύματα
  • Twitter:@jwr_
  • GameCenter:jwr_p
Δημοσίευση 23/11/2009 - 00:06
Με αυτή την εφαρμογή που μόλις κυκλοφόρησε μπορείτε να γίνετε DJ και να πάρετε το iPhone σας και να παίξετε μουσική σε ένα πάρτυ κυριολεκτικά!
TouchDJ Features:
  • “Visual mixing,” with a clever interface that uses overlays atop side-by-side waveform views
  • Pre-listening using a special left/right adapter
  • Faux vinyl and spin effects
  • Real-time scratching, looping, positioning, EQ, effects, re-pitching
  • Onboard sampler with 3 WAV sample slots, recording from the mic
  • Uses a separate MP3 library with companion apps, since it isn’t possible to DJ from the library you sync from iTunes
FULL-BLOWN MP3 DJ SOLUTION
Touch DJ ™ by Amidio Inc is the first and only real MP3 DJ mixing app available for the iPhone.
Touch DJ (click for iTunes page) offers realtime independent manipulation of 2 MP3/M4A files, including scratching, looping, positioning, equalization, effects and and pitching.
The unique futuristic user-friendly interface of Touch DJ and the highly advanced zero-latency sound engine bring fantastic results comparable to what can be done with professional hardware equipment worth at least $1000.
VISUAL MIXING - EXPERIENCE NOW!
Traditionally iPhone and iPod Touch have only one stereo audio output which broadens the possibility of using them as a DJ device. Touch DJ overcomes this limitation by offering innovative and unique way of deejaying which doesn't require additional headphones for prelistening to the tracks.
This technology is called "visual mixing" and it implies the graphic display of the track waveforms next to each other. The low-bass (kick) parts are detected and rendered in different color compared to the rest sonic frequencies, making beatmatching as easy as adjusting the tracks position and pitch so that the kick parts become visually matched.
THE NEW WAY TO DJ
Touch DJ is a completely new way to create stunning DJ mixes whenever you like. You can touch and feel your tracks, move around them, scratch them, EQ them, loop them, and mix them even without prelistening.
SPLIT MODE
As an alternative for the users who really need to prelisten to the tracks, Touch DJ also offers a second "Split" mode of mixing which requires the usage of a special L/R splitting adapter.
EXTRA FEATURES
Among extra features - LP filter FX for each track, vinyl Spin and Break effects, onboard sampler with 3 sample slots (accepts .WAV files) and the ability to record samples via the microphone. As a bonus, Touch DJ is shipped with 25 dance tracks provided by DanceMusicHub.com so that you will be able to start jamming away instantly.
IMPORTANT!
Currently it is impossible to get the music from the iTunes music library. This is a technical restriction which cannot be resolved. Touch DJ uses its own MP3 library. To get your own music into Touch DJ: use Wi-Fi (slow) or companion programs (fast) available for PC (Win) and Mac OSX. Contact us at support@amidio.com if you need any help regarding getting your own music into Touch DJ.
Και ένα βίντεο που παρουσιάζει το καινούργιο app:
http://www.youtube.com/watch?v=lWAFxeHpmvs
Και ένα mix:
http://www.youtube.com/watch?v=0KjTbwR9oeY
[via engadget - Amidio]
[iTunes link - Τιμή:15,99€]
#2   AlexK
AlexK
  • 1.440 μηνύματα
  • GameCenter:Alexkdef
Δημοσίευση 23/11/2009 - 02:23
Παίζει να είναι από τις καλύτερες DJ Εφαρμογές! Καιρό έψαχνα κάτι καλύτερο από το Quixpin... Ευχαριστώ
#3   djmanosv
djmanosv
  • 615 μηνύματα
  • Twitter:@m_vogiatzis
  • Tablet:iPad mini +4G
  • GameCenter:djmanosv
Δημοσίευση 23/11/2009 - 03:00
TELEIO !!
#4   MixalisXxx
MixalisXxx
  • 2.047 μηνύματα
Δημοσίευση 23/11/2009 - 05:29
Αν είναι έτσι όπως τα βίντεο είναι πραγματικά καταπληκτικό!!!
#5   DJACID
DJACID
  • 419 μηνύματα
Δημοσίευση 23/11/2009 - 19:29
Μολις το κατεβασα και εγω και σε λιγο θα το δοκιμασω. Το βρηκα σπασμενο απο ενα site κινεζικο.Θα το ανεβασω σημερα αν προλαβω στο γνωστο μαγαζακι.
#6   ktm
ktm
  • 1 μηνύματα
Δημοσίευση 25/11/2009 - 15:11
καλισπερα επειδη ειμαι κενουριοσ μιποσ μποριτε να μοθ πειτε πιο εινια το:γνωστο μαγαζακι.
u
#7   ProSONIC
ProSONIC
  • 775 μηνύματα
Δημοσίευση 25/11/2009 - 19:45
παιδια μπηκα σημερα στο γνωστο σαιτ για να την κατεβασω την βρηκα αλλα δε εμπιανε μεσα που δειχνει την φοτο και την version για να το κατεβασω ενω σε αλλα εμπαινε... απο το install0us πηγα να το κατεβασω...
#8   AlexK
AlexK
  • 1.440 μηνύματα
Δημοσίευση 25/11/2009 - 19:47
Δοκίμασες να το κατεβάσεις απο το PC σου και να το συγχρονίσεις στην συνέχεια ????
#9   ProSONIC
ProSONIC
  • 775 μηνύματα
Δημοσίευση 25/11/2009 - 19:55
οχι ... γι αυτο εβαλα το install0us για να μην παιδευομαι.... αλλα δε μου κανει τα χατιρια... και την ηθελα τοσο... θα δοκιμασω αυριο να δω ... μπορει να επαιζε τιποτα,το μονο που με νευριασε ηταν οταν με εβγαλε την ερωτηση..ας ειναι καλα το φορουμ.. και γι αυτο ειπα οτι ηταν ευκαιρια να το κατεβαζα απο κει απευθειας... ευχαριστω για την αμεση απαντηση...
#10   iPodTouchPro
iPodTouchPro
  • 3.187 μηνύματα
Δημοσίευση 26/11/2009 - 18:42
Τα σπάει η εφαρμογή!!Καιρό έψαχνα μία τέτοια αν και τσουχτερή η τιμή του... :(
