springboard_ss.png 148.48KB
18 downloads
settings_ss.png 63.66KB
11 downloadsIconoclasm is a tweak that lets you break the barriers of what you can do with your icons. Previously, you had to deal with multiple extensions that didn't necessarily play nice with each other, or use blank web clips. Not anymore.
You can define as many rows or columns you want. You can even break free from rows and columns, and simply have icons placed freely on your home screen. It's all up to you
Λειτουργεί από την έκδοση 3.0 και πάνω ενώ χρειάζεται το Mobilesubstrate και το Preferenceloader.
Τιμή: $1.80
[Πηγή: Modmyi]
Τελευταία επεξεργασία από: michaelkrtikos, 15/12/2009 - 06:23.
