Διαθέσιμες είναι από σήμερα οι αναβάθμισεις των Word, PowerPoint και Excel της σουίτας Office for iPad με πολλές νέες δυνατότητες όπως αποστολή PDF αρχείων από τα Word και Excel, νέο Presenter View στο PowerPoint κ.α. Πιο συγκεκριμένα:
Microsoft Excel for iPad 1.1
What’s New in Version 1.1
- Send PDFs: You asked, we listened. Now you can send Excel files as PDFs.
- Flick to Select: Flick a cell’s selection handle in any direction to quickly and easily select all the data in a row or column.
- External Keyboard Support: Using an external keyboard is even easier. Use the same keys to input data and move around a worksheet as you would on your PC or Mac.
- PivotTables: Interact with PivotTables that have source data in the same workbook.
- Print Options: More paper sizes and scaling options give you more control over the layout when printing your workbooks.
- Picture Tools: Crop to focus on just the right part of the photo, or reset to undo your changes.
- Fonts: Third-party fonts are now available in the Fonts menu.
Microsoft PowerPoint for iPad 1.1
- Presenter View: View and edit speaker notes, see your next slide, or jump to other slides while presenting.
- Play Media: Play videos, sound effects, and background music while presenting.
- Insert Video: Insert videos from your Camera Roll.
- Presenter Tools: Now you can erase highlights and drawings on your presentation.
- Send PDFs: Send PowerPoint files as PDFs.
- Hyperlinks: Add links to your presentation or edit existing ones.
Microsoft Word for iPad 1.1
- Send PDFs: You asked, we listened. Now you can send Word files as PDFs.
- Picture Tools: Crop to focus on just the right part of a photo, or reset to undo your changes.
Τα Word (iTunes link), PowerPoint (iTunes link) και Excel (iTunes link) για iPad μπορείτε να κατεβάσετε δωρεάν από το App Store, για να κάνετε χρήση όμως όλων των λειτουργιών απαιτείται συνδρομή στο Microsoft 365 (in-app purchase).
