Παραθέτω αυτούσιες τις οδηγίες από το site του netputing.com.
Download:
Download the latest version: AirPrintHacktivator v1.7.1
You can also download previous versions by clicking the version number link in the “Software revisions” section below.
Description:
AirPrint Hacktivator is based on the Troughton-Smith hack. Version 1.0 to 1.6 essentially automated the addition a urftopdf mime types reference to two cups files and add a urftopdf filter for cups.
Starting with version 1.7 only the following two lines are added to the “/usr/share/cups/mime/apple.types” file:
# Added by AirPrintHacktivator
image/urf urf string(0,UNIRAST<00>)No Apples files are redistributed nor installed by the latest version. A backup of the original file is done prior to adding the necessary line to allow for easily reverting the hack.
HOW TO Hacktivate:
1. Launch AirPrintHacktivator
2. Click on the togle switch:
3. Enter the admin password:
4. A window will appear instructing you to remove/add/share the printer you want to use with AirPrint:
Click OK.
5. The Print & Fax System Preference window will open to allow you to perform the remove/add/share task. The following youtube clip will show you how:
http://www.youtube.com/watch?v=Id5VOiO8Jd8
Simply make sure you select your printer that is listed on your Mac and not “CUPS-PDF” as in this video.
[via]
UPDATE:
Μετά από απαίτηση της Apple ο developer απέσυρε το tool Hactivator.
Δεν αλλάζει όμως κάτι, εφόσον ανέβασε το tool Activator και πραγματοποιεί το hack με διαφορετικό τρόπο.
Η διαδικασία είναι η ίδια.
Download the latest version: AirPrint Activator v1.0
Apple requested that I take down the AirPrintHacktivator page as they stipulate that the application is distributing copyrighted source code and/or software. AirPrint Activator is now replacing the defunct AirPrint Hacktivator application. It provide the same functionality without the use of any Apple files.
You can use AirPrint Activator as a replacement of the previous generation Hacktivator application. If present, it will take care of cleaning any Apple files installed by the previous generation Hacktivator when you “deactivate” AirPrint. It will only inject a single line in a CUPS configuration when you select to “activate” AirPrint.
System Requirements:
* OSX Snow Leopard 10.6.5
* iTunes 10.1
HOW TO activate AirPrint:
1. Launch AirPrint Activator
Click OK.
5. The Print & Fax System Preference window should now open to allow you to perform the remove/add/share task. If it does not then simply open System Preferences/Print & Fax. The following youtube clip will show you how:
Ακολουθήστε τις οδηγίες στο παραπάνω video.
Make sure you select your printer that is listed on your Mac and not “CUPS-PDF” as in this video.
Τελευταία επεξεργασία από: mikexs, 06/12/2010 - 09:11.
