'iPhone Explorer' USB iPhone browser
Δημοσίευση 04/09/2009 - 10:15
Χαρακτηριστικα:
- 100% Free iPhone browser for Mac and Windows
- 100% Drag-and-drop interface for easily copying files to and from your iPhone
- Easily integrates with Good Reader so you can view any transferred files directly on your iphone
- Create, delete and rename files and folders on your iPhone or iPod Touch
- Works with all iPhones and iPod Touches including the iPhone 3G and iPod Touch 2G
- Allows you to use your iPhone as a flash drive / pen drive or put your iPhone into disk mode
- Tiny download size
- (Optional) If you jailbreak your iPhone you can access the real root of your iPhone and recover your address book, SMS, e-mails and more.
[iPhone explorer website]
Δημοσίευση 04/09/2009 - 10:46
Δημοσίευση 04/09/2009 - 10:48
Δημοσίευση 04/09/2009 - 10:50
Δημοσίευση 04/09/2009 - 10:55
USB file transfer
PC Windows & Mac OSX compatibility
Supports iPhone V1, 3G, 3G S & iPod Touch V1 and V2
Auto detection feature, just plugin it in !
Copy Files & Folders between your iPhone or iPod Touch and your Computer
Files and Folders Browser
Drag & Drop files and folders
Device's free memory displayed
Bookmark files and folders
Feature rich file organization including folder creation, renaming... etc.
File & Folder information window.
No jailbreak needed (Needed to access the Root Folder)
Supported firmware versions : 1.1.1 to 3.0
iphone explorer
* 100% Free iPhone browser for Mac and Windows
* 100% Drag-and-drop interface for easily copying files to and from your iPhone
* Easily integrates with Good Reader so you can view any transferred files directly on your iphone
* Create, delete and rename files and folders on your iPhone or iPod Touch
* Works with all iPhones and iPod Touches including the iPhone 3G and iPod Touch 2G
* Allows you to use your iPhone as a flash drive / pen drive or put your iPhone into disk mode
* Tiny download size
* (Optional) If you jailbreak your iPhone you can access the real root of your iPhone and recover your address book, SMS, e-mails and more.
ifunbox
Navigation, Upload and Download
> Quick Preview, Drag&Drop
> Delete, Rename and Move
> Asian / Long Filename Support
>iPhone Portable Disk
> Realtime Progress Indicator
> High Speed Data Transmission
> Scheduled Data Transferring
> Recursive Copy Subfolders
>Managing iPod Music & Movie
> iTunes© Managed Media Files
> Upload Songs and Movie
> Sort and Selection
> Copy to PC with Friendly Title
> Image Thumbail Preview
> Batch Uploading and Conversion
> Change Image Resolution
> High Quality Image Resizing
>Upload Wallpaper in Batch
Δημοσίευση 04/09/2009 - 10:56
Δημοσίευση 04/09/2009 - 10:58
Δημοσίευση 04/09/2009 - 10:59
Δημοσίευση 05/09/2009 - 11:27
Δημοσίευση 05/09/2009 - 12:29
Μπορείς και με το iFιle να αλλάξεις τα permissions...αλλαγές file/folder permissions δεν κάνει κανένα δλδ έ? α ρε ssh...
Όσο να ναι το SSH στην ουσία είναι υπηρεσία που ξεκινάει αυτόματα σε κάθε reboot της συσκευής και πρέπει να το απενεργοποιήσεις μέσω του sbsettings. Οπότε νομίζω ότι εάν βγει μια καλή εναλλακτική λύση καλό θα ήταν να πάρει πόδι το SSH από τη συσκευή, μια υπηρεσία λιγότερη...Oταν κατι δουλευει σωστα (ssh) γιατι να το αλλαξεις ?
Δημοσίευση 05/09/2009 - 12:42
Λίγο πιο αναλυτικά;...
Δημοσίευση 05/09/2009 - 13:26
Σωστο και αυτόΜπορείς και με το iFιle να αλλάξεις τα permissions...
Δημοσίευση 05/09/2009 - 13:41
Πατάς επάνω στο βελάκι που βρίσκεται στη δεξιά πλευρά κάθε αρχείου η φακέλου και μετά πηγαίνεις στο Access Permissions και τ' αλλάζεις...
Δημοσίευση 07/09/2009 - 01:12
Δημοσίευση 10/09/2009 - 13:43
Έκανα απεγκατάσταση και μετά ξανά εγκατάσταση αλλά τίποτα...
